R Roger cf Reputable Nov 8, 2015 2 0 4,510 Feb 18, 2016 #1 A T.D.K Speaker receiver plugs into USB on my Laptop just fine. Can I plug it into the Hisense smart TV? The Bluetooth Mouse, works fine on the Smart TV
Solution hang-the-9 Feb 18, 2016 If the TV has bluetooth, it should work with the speaker although you'd want to check with the manual or support site for your TV.
hang-the-9 Titan Mar 25, 2010 60,372 1,081 152,940 Feb 18, 2016 Solution #2 If the TV has bluetooth, it should work with the speaker although you'd want to check with the manual or support site for your TV. Upvote 0 Downvote Solution
A americanaudiophile Titan Aug 27, 2008 13,663 0 101,360 Feb 19, 2016 #3 You can try plugging the speaker into the TV USB port but it probably won't work. TVs don't usually have the right drivers. Can't hurt to try. Upvote -1 Downvote
