How does a UPS work?
JohnD7
19
I wanna know the basics to avoid connecting too many things to it or puttin too much stress on the power outlet which its gonna be connected to
let me see if i can give you a easier to understand and more thorough answer.
as far as what can be hooked up to your wall outlet that does indeed have to do with your house wiring diagram. typically anywhere from one or two to as many as all the outlets in a room are wired together and will terminate at the circuit breaker. the wiring in your house may be able to support 15amps or 20amps and this is the size of the circuit breaker in the main breaker panel. all of the devices will need to draw less than this total or the circuit breaker will trip causing you to lose power. this is done for safety so you do not melt the wires in your house. i found a source which ways that a 20a circuit can support 2400watts maximum but should only be...
I'l admit I am not knowledgeable in this area, but I will tell what I know.
If the power is on, you could probably plug as many things into the UPS as is reasonable, at that point all it is doing is smoothing the power coming from the wall. When the power goes out, it will try to power all the stuff connected too it, so if you have too much it will go out pretty quickly. So if your wanting to keep your computer on in a power outage, what you would want to do is only connect the computer and a monitor to the UPS, that way you will have some time to save whatever your doing before it drains.
As for overloading your wall socket, thats going to depend on your house wiring. Nothing exact I can really say here, just that if you dont plug an ungodly amount of things or something of ridiculously high wattage into it chances are you'l be fine. You could get an electrician to check if you really want to know how many Watts it can support.
Hi
UPS units are rated on the maximum power they can handle when the power is off and it is running on battery,this will be quoted as VA or watts .
You will need to assess the wattage of all the items plugged into it and get a UPS with a higher power rating than this.
Normally you would only plug essential items into it like PC and monitor but not printer or desk light in order to maximise battery life.
as far as what can be hooked up to your wall outlet that does indeed have to do with your house wiring diagram. typically anywhere from one or two to as many as all the outlets in a room are wired together and will terminate at the circuit breaker. the wiring in your house may be able to support 15amps or 20amps and this is the size of the circuit breaker in the main breaker panel. all of the devices will need to draw less than this total or the circuit breaker will trip causing you to lose power. this is done for safety so you do not melt the wires in your house. i found a source which ways that a 20a circuit can support 2400watts maximum but should only be ran on 80% of that number or 1920w
if you have a single circuit connected to the breaker this means that you can pull that from the one wall outlet however if you have multiple outlets or even the ceiling fan hooked up to the same circuit (depends on how well the person wired your house) this total is spread across all of the connected devices. this is why in kitchens outlets are often either on their own loop or placed in small clusters since many devices (microwaves, blenders, tabletop convection ovens, etc) draw quite a bit of power and shouldnt all be ran on the same circuit at the same time.
if you want to know how many amps are being drawn perhaps you should get a kill-a-watt which will tell you exactly how much power devices draw.
as far as how much draw (power requrements of all connected devices you plug in) you can place on a UPS this is determined by the maximum wattage on the unit. keep in mind that the closer you come to the maximum wattage the shorter your actual back up time will be.
for instance... i am personally using a xs 1300 apc upc which is rated for 780w maximum. my computer can draw anywhere from about 150w to 450w or perhaps a bit higher depending on what i am doing at the moment. playing a very demanding game for instance will draw alot of power. not counting a monitor into the equation i would get about 6-7 minutes of runtime in a loss of power situation. with a monitor reduce this by a minute or two. with the television i currently use i'm looking at around 3-4 minutes at full load of power.
at minimum load i could run about 20-25 minutes.
keep in mind that this is not a cheap ups and has a msrp of about $200. unless you spend an extraordinate amount of money or use some custom car battery system in your basement as a source of power with an inverter and other hardware you will not be able to power a huge amount of equipment.
all the ups is meant for is to plug your pc+monitor into so that when the power goes out you dont damage your pc from a blackout. you then have time to save your work and shut down. it is not meant to keep working for hours and hours unless you have a low power demand system (either a low end desktop or laptop) connected up to it.
some of the cheaper $50-100 are almost completely useless for gaming systems.
i hope this helps you to get an idea how everything works and what you should be looking into.
