G
Guest
Guest
Archived from groups: rec.games.roguelike.nethack (More info?)
Can anyone tell me how multiple patching works for nethack? i.e. if I
wanted to use joe's foohack and fred's barhack, I would think they
would overwrite (or add) original code. If so, does the second patch
blow away the first one? Can you safely add multiple patches unlimited
or do you have some kind of limit to worry about? i.e. only so many
times you can write over foo.c etc...
Second, do the patches affect the bones files? Would they still be
compatible with hearse, etc?
Thanks for your help in advance
tiny k
tiny k
