How does Asus auto tuning work?
Tradesman1
There's both software based and BIOS based auto tuning with the Hero, I'd go the hardware version via the BIOS, it examines and test things at 4.2, 4.4, or 4.6 and decides what your components can need to run at, it works fairly well, then when you are stable can go in and often lower voltages, or if you want to try higher you will have an idea of what was changed (if you took screen shots of the base settings) and can increase the OC
