How does GPU Boost 2.0 work on GT 940MX?
NDDU Julius BSIT
Respectable
May 19, 2016
476
I've been watching the statistics of my GPU lately. Overclocked Core clock to 135 and memory clock to 245 but after a while, the CPU clock goes down from 1336 MHz to 1121 MHz and I notice a little more stuttering. Is GPU Boost 2.0 even working? or am I doing something wrong? Overclocking a laptop is pretty dumb and I cannot afford a top-tier gaming laptop and overclocking seemed to improve both my gaming FPS and rendering performance for Auto Cad or Adobe products.
I do have a gaming rig but I am mostly at school rendering these stuff and play some games like DOTA 2 or Overwatch and etc.
Hi,
GPU Boost 2.0 is working just fine. It basically pushes your GPU to give you the maximum performance when needed and once your GPU reaches a certain high temperature after prolonged heavy use, the GPU Boost 2.0 decreases the GPU clock speed to let your GPU cool down for a bit. It then throttles back to maximum clock speed and repeats the process.
I am assuming you actually meant GPU?
I am not aware of any such methods unfortunately. You can manually increase clock speeds of your CPU, GPU, etc (if supported) but I would highly recommend against it. There is a reason Nvidia has a "maximum operating temperature" set and you will end up burning your card or worse if you manipulate with it.
I get "ORANGE" screens of death after too much overclocked values though. Thanks for the info
