How does my build look?
ADHD-MI
Commendable
Aug 2, 2016
4
Are there any tweaks or suggestions to my build that you have? I like to play games like the wither 3 and fallout 4 with ultra-settings. I like to modify games with a lot of mods. I hope that kind of helps you envision my wants and needs.
Here is the build: http://pcpartpicker.com/list/VcDNqk
Perfect.
Build looks great man, should easily run most or if not even all upcoming games at 1080p 60fps. If you want to overclock your GPU then go for a higher wattage Psu. Fallout 4 should run easily above 60fps at ultra at all times at 1080p. Same with Witcher 3, if not then toggle Nvidia hairworks off when playing. Then it should garrantee +60 fps on witcher 3.
You are leaving 30% cpu performance on the table without a Z170 motherboard.
Rest looks ok, but
FWIW.
I will never again build without a ssd for the "C" drive. It makes everything you do much quicker.
120gb is minimum, it will hold the os and a handful of games. If you can go 240gb, or 500gb you may never need a hard drive.
I would defer on the hard drive unless you need to store large files such as video's.
It is easy to add a hard drive later.
Samsung EVO is a good choice.
I went with that HD because its a hybrid and its suppose to be 20% faster then a normal HD. I was looking for a good medium between price and proficiency. Would you suggest I still get a SSD?
I have made two new changes to the build I added the SSD and changed the mother board. What do you think about the changes? Also thanks for the help; I really appreciate it.
http://pcpartpicker.com/list/CdpskT
Perfect.
