How does my water cooling build look?
You did a good job: nice looking build... The extender (metal tip) in the reservoir increases the distance between the inlet and the outlet: it helps to reduce turbulence.
fasty1
33
I heard that you can make a twister water effect with a cylinder reservoir. Did i hear wrong?
thenewnumber2
275
There was a reservoir like that on the market a few years ago, but I don't remember the manufacturer. I think it was not widely liked: the vortex had a habit of introducing air into the outlet. It definitely looks cool, though. But I don't know the method to create a vortex effect, you'll have to google around a bit.
EDIT: changed "inlet" to "outlet"
