I'm planning a high airflow and quiet system using the Dark Rock Pro 3 and some form of advanced GPU (Potentially Strix 1080 ti). I'm considering using a Z270E MB and intend on using the Dark Base Pro 900.
My current problem;
In order to maximize airflow in the case during high loads I plan to put 9 Silent Wing 3 PWM 140mm fans all around (rear:1 exhaust; top:3 exhaust; front: 3 intake; bottom: 2 intake). The fan hub however can only take 4x4pin fans and 4x3pin fans.
How should I go about connecting these whilst also having the PWM funktion in all of the fans.
I'm don't know if this is a simple problem but I, as a very unexperienced builder, find this quite confusing and I find very little in the ways of a solution. Thanks in advance for any helpful responses.
My current problem;
