How does the auto paper sensor work?
mo
339
Archived from groups: comp.periphs.printers (More info?)
Some printers have an auto paper sensor that can determine the type of
paper to be printed and set the driver to the proper setting.
1. How does it know the paper type?
2. How can it be defeated to test different settings?
I think my Canon i960 printer has the auto paper sensor since I
printed on photo glossy paper with out chaning from the plain paper
setting and the printout turned out OK.
I'm not sure if the auto paper sensor is overriding any settings I
make.
> make.
Did you try to print same image to photo paper using setting "photo" and see
if it's any difference? Of course it's a difference between plain paper and
photo one - even at lower resolutions. But, normally, if you set plain, you
can't print with highest resolution (like 4800 dpi) and here's the basic
difference when setting paper type. You probably printed with 2400 DPI or
similar.
When printing with i960 to photo paper, image must not turn out OK, but
PERFECT...
