How does this build will preform and is it compatible ?
Drooz
26
Hey guys what do think of this build I'm doing it for gaming
CPU : AMD Athlon X4 860K Black Edition 3.7GHz
Motherboard : ASRock FM2A88X Pro3+
Ram : Kingston ValueRAM 4GB DDR3 1600MHz CL11 SR x8 Low Profile
GPU : GIGABYTE GeForce GTX 950 WindForce 2X OC 2GB DDR5 128-bit
HDD : Hard disk WD Blue 500GB SATA-III 7200 RPM 32MB
PSU : Corsair NEW VS Series VS650
Case : Deepcool Tesseract BF black
Monitor : LED Philips 223V5LSB/00 21.5 inch 5ms black
OK for a tight budget build
You NEED 8gb ram for gaming
If you can find a RX 460 card for less or equal to the 950 it's a little stronger .
The vs is not a great quality PSU, if that's the brand you're stuck with it'll do the job though.
You don't need the 650, the 450 or 550 are enough
That a88 board , how much is it??
There are some 68 boards that should be cheaper & will do exactly the same job
For thr Ram *2
GPU I will change it I found RX 460 for better price but the Benchmark FPS was Higher for 950
and yeah PSU I'm stuck with it
What you'll find with the rx 460 vs 950 is that its fairly even up to a point , 2-3fps depending on game title.
& then you get the odd title which uses DX 12 to some extent , doom, hitman, tw:warhammer are the big 3 , where the difference is massively pronounced at around 30% or so.
Due to this I personally think a year fownbthe line the 460 is going to be the better performer & much better supported.
Latest posts
