How good are these parts for a gaming pc?
Alex_173
Commendable
Mar 1, 2016
I'm going to be building a new PC for the first time and was wondering how good some of the parts I was looking at are or if I should be looking for something else.
Motherboard
ASRock ASRock Fatal1ty Gaming Z170 Gaming K4 LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
CPU
Intel Core i5-6600 6M Skylake Quad-Core 3.3 GHz LGA 1151 65W BX80662I56600 Desktop Processor Intel HD Graphics 530
Heat sink
Cooler Master Hyper 212 EVO Universal CPU Cooler
Video Card
EVGA GeForce GTX 970 04G-P4-3975-KR 4GB SSC GAMING w/ACX 2.0+, Whisper Silent Cooling Graphics Card
RAM
G.SKILL Ripjaws 4 Series 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 2133 (PC4 17000) Memory Kit Model F4-2133C15D-8GRR
Hard drive
WD Blue 500GB Mobile 7.00mm Hard Disk Drive - 5400 RPM SATA 6 Gb/s 2.5 Inch - WD5000LPVX
WD 2TB 7,200 RPM SATA III 6Gb/s 3.5" Internal Hard
Solid State drive
SanDisk SSD Plus 240GB SATA III 6Gb/s 2.5" Internal Solid State Drive
Case
NZXT Crafted Series 921RB-001-BL Black SECC Steel / ABS Plastic ATX Mid Tower Computer Case
Power supply
Newton Power LTD N1000P
for an optical drive I plan on just using one from one of my old PC
The Newton Power LTD N1000P was a good psu. It would be fine with a GTX970. It's just a little old now. I haven't seen one in 5 or 6 years at least.
-Go with the cheaper H170 board (though I prefer Gigabyte for mobos)
-The coolermaster heatsink will be good, although not entirely needed since you wont be overclocking.
-Video card is good
-I would suggest going with 16gb of ram since windows alone will eat up over 4gb
- You only need one traditional hard drive. If buying a new one, go with a western digital black series.
- The sandisk ssd is good. Have one of those myself.
- For the PSU, I would go with either SeaSonic (preferable) or Antec. You do not need a 1000W psu either. A good 650 or 750W seasonic will be more than enough. (The gpu requires 300, cpu is 95, the rest is trivial). http://outervision.com/power-supply-calculator
