S sam_pink Honorable Nov 27, 2013 34 0 10,530 Jan 8, 2014 #1 Intel Core i5 750 CPU @ 2.67 GHz 6GB DDR3 RAM (PC3 10600) 250GB Western Digital SATA II Hard Drive nVidia GeForce GT220 1GB (PCI-Express 16x) DVD-RW Drive (SATA) Onboard Sound Card and how much would say its worth
Novuake Champion Aug 27, 2011 14,302 0 56,960 Jan 8, 2014 #2 You need a MUCH better graphics card. Depending on the power supply it has, that you neglected to mention, you can get a better card. Upvote 0 Downvote
Foldalot Honorable Oct 3, 2013 738 0 11,360 Jan 8, 2014 #3 Here's a GPU that will fit well assuming the PSU can support it Asus HD 7770 DirectCU Upvote 0 Downvote
chimera201 Splendid Apr 19, 2012 2,738 2 21,465 Jan 8, 2014 #4 http://www.cclonline.com/product/120051/11201-17-20G/Graphics-Cards/Sapphire-Radeon-HD-7770-GHz-Edition-1GB-Graphics-Card-PCI-E-DVI-HDMI-DisplayPort/VGA1779/?siteID=8BacdVP0GFs-jF9_EtKdG20KJhPvTgMZVg What's your PSU? Upvote 0 Downvote
S sam_pink Honorable Nov 27, 2013 34 0 10,530 Jan 8, 2014 #6 and what sort of games can i run at what fps in i get a new gpu Upvote 0 Downvote
Foldalot Honorable Oct 3, 2013 738 0 11,360 Jan 8, 2014 #7 You need to be more specific, brand and model? Although HD 7770 doesn't require much so you should be ok even with a cheap PSU. Upvote 0 Downvote
chimera201 Splendid Apr 19, 2012 2,738 2 21,465 Jan 8, 2014 #8 sam_pink : my psu is 500w we need psu model not the wattage Upvote 0 Downvote
S sam_pink Honorable Nov 27, 2013 34 0 10,530 Jan 8, 2014 #9 i dont know bit the pc is a Dell Vostro 430a and i have not changed the psu Upvote 0 Downvote
Foldalot Honorable Oct 3, 2013 738 0 11,360 Jan 8, 2014 #10 Open the PC case and take a photo of the PSU label. Upvote 0 Downvote
S sam_pink Honorable Nov 27, 2013 34 0 10,530 Jan 8, 2014 #11 Power Supply: 350W, 115/230VAC (Equipped with Selector Switch) 50/60Hz that is the best i can do i my phone camera broke Upvote 0 Downvote
Foldalot Honorable Oct 3, 2013 738 0 11,360 Jan 8, 2014 #12 You said that your PSU is 500W.... If it's a generic 350W then you might blow it with a new GPU. Upvote 0 Downvote
S sam_pink Honorable Nov 27, 2013 34 0 10,530 Jan 8, 2014 #13 i taught it was a 500w but its not what is the cheapest psu that can run the 7770 Upvote 0 Downvote
S sam_pink Honorable Nov 27, 2013 34 0 10,530 Jan 8, 2014 #15 thanks what about this Raidmax Hybrid RX-630SS 630W ATX12V/EPS12V Power Supply Upvote 0 Downvote
Foldalot Honorable Oct 3, 2013 738 0 11,360 Jan 8, 2014 #16 Avoid Raidmax, that's a cheap PSU brand which will cause you more trouble in the future. Upvote 0 Downvote
S sam_pink Honorable Nov 27, 2013 34 0 10,530 Jan 8, 2014 #17 ok with the psu u said and a 7770 will it run battlefield 4 in what setting and fps Upvote 0 Downvote
Foldalot Honorable Oct 3, 2013 738 0 11,360 Jan 8, 2014 #18 Medium settings on 900p should provide 50+ FPS Upvote 0 Downvote
S sam_pink Honorable Nov 27, 2013 34 0 10,530 Jan 8, 2014 #19 good what about ACE 600W BR PSU for a psu Upvote 0 Downvote
Foldalot Honorable Oct 3, 2013 738 0 11,360 Jan 8, 2014 #20 That's another cheap brand of PSUs, where do you even find these? Upvote 0 Downvote
S sam_pink Honorable Nov 27, 2013 34 0 10,530 Jan 8, 2014 #22 what would u value it at with windows 7 ultimate Upvote 0 Downvote
Foldalot Honorable Oct 3, 2013 738 0 11,360 Jan 8, 2014 #23 Look for : Antec, XFX, Corsair, Seasonic. Choose only from those brands. Upvote 0 Downvote
S sam_pink Honorable Nov 27, 2013 34 0 10,530 Jan 8, 2014 #24 ok thanks for the help Upvote 0 Downvote
