How Hard Is It To Adjust to Mechanical Kyboards?
TronX33
85
I am a person used to laptop membrane keyboards and am looking at buying either the Corsair K70 Brown keyboard, or the Logitech G710 (not 710+, just the 710 with Cherry MX Blue). I am aiming to sue the keyboard for gaming. I have heard that the reset point of the blue switches are hiher than those of the Brown, so you can't double tap as fast as the Browns, however, I have listened to sound comparisons, and really find the sound of the blue switches very satisfying. I do not want any other switches because of higher actuation forces, and not the Red switches because there is no feedback to tell you when t actuates, which will probably make me more likely to treat them like membrane keys. So, which keyboard or switch do you recommend?
I have a Rosewill 9000bl with cherry black switches, and I like it, I came from a membrane, this is my first mechanical keyboard, I wanted the blues though, so that's what I'll be getting next, and I don't recommend buying one that has a detachable cable, that's what this Rosewill has, and when I move the keyboard even a little it disconnects. Not too much of a problem on my desk, but when I sit back and put the keyboard on my lap I can't use it any more. My little brother likes the membrane keyboards, but he's only used mine once, and the reason he didn't like it was the distance you have to press the keys.
