How hard is it to replace components?
One1
60
I just bought a new video card, cpu, motherboard, ram, and power supply. How hard will it be for a fifteen year old to install these components into his computer in order to replace the older components? Thanks.
Hey buddy! I was 14 when I first tinkered with my pc. I remember, the first thing I did was take out the RAM, then take all the cables out. I'll never forget that! Just shout if you need any help! PM me if you want! GOOD LUCK!!!!!!!
Did you ever play with LEGOs as a kid? youll be fine :] .
Build it on wood, not carpet (avoid sparks). employ lots of common sense and youll be fine. As for order of operations, it will make sense. (i.e motherboard in first, and CPU in before the cooler lol, etc)
