I purchased a Gateway LX6810-01 about 13 months ago and within the last couple of weeks, the thing is just powering off with no warning. I play WoW a lot, and this is typically when it will shut down. I can sometimes play for an hour...sometimes 5 minutes - then black screen without any warning.
I have checked out a couple of postings about this model of computer and found that it has some issues with overheating and such (YAY Gateway)... My main concern is that I am going to ruin the computer if I don't upgrade something...but I don't know what. I have some friends that say that the power supply is most likely causing the computer to overheat and power off - but that just doesn't seem right to me...but then again, I am here asking, which means I do not know too much about computers. I downloaded SpeedFan to monitor, and get a feeling for the computer temperatures, and this is what I usually get:
GPU: 140F
Temp1: 93F
Temp2: 84F
Temp 3: 70F
Core 0: 108F
Core 1: 95F
Core 2: 102F
Core 3: 102F
The shutting down usually happens around 170~ or so...which in my opinion is way too hot...
I went and purchased a new heat sink...but it appears that with this model of computer, I am going to have fun looking for one that will actually work with the motherboard. The type that is installed onto the core/motherboard has "screws" holding in the heat sink...and I purchased the kind that you lay on top of the core, and pop right in the motherboard. I have taken this back, and cannot find one to replace the current one at all (YAY Gateway, again). This model of computer also has no case fans...so I will be getting two in the near future to remedy this problem - the only fans that it has are the heat sink fan, a fan on the graphics card, and the outtake fan from the powersupply.
Any help or suggestions would be greatly appreciated...as I spent quite a bit of money on this system and do not want it to crash on me.
Thanks for your time!
GPU: 140F
Temp1: 93F
Temp2: 84F
Temp 3: 70F
Core 0: 108F
Core 1: 95F
Core 2: 102F
Core 3: 102F
