[SOLVED] How i add molex power in dell 7910
Jan 29, 2020
5
Please let me know and kindly brefly describe me about my question ?
How i add molex power connector in my dell T7910 .
Because there is no option .
Tell me how i add molex power and sata power conneters in dell T7910 Tower.
Send me link if availabe !
I ask this question becasue i have internal Usb 3.0 Hub and that Hub requiers molex power connecter..
Note :-
Molex power connecters or use in old pcs like dell t7500 dell t7400
But
I want that Connecter in my dell T7910
And
My second question is
In mother board there is a usb port
For what purpose is that and how i use that port ?
Do you mean that you wish to convert from the newer SATA power connector to the old 4-pin Molex power connector?
If so, then you perhaps need an adapter like this:
Molex splitter.
For example:
https://www.monoprice.com/product?p...MIyf7s4e-75wIVBo_ICh1M5g6KEAQYBCABEgIzK_D_BwE
For power google "Molex SATA power adapter"
As for the motherboard's internal USB port I would expect that you could use the port much like any other USB Port.
However, I recommend that you download the motherboard's User Guide/Manual and read the applicable section regarding the use of the port. There may be some restrictions or caveats involved. Details matter.
Not good ans for me you tried hard i apriceated
But there us no search about molex connect on google
I try search on.google but no result found
Kindly explain me in detail
Your Power Supply should have at least one molex adapter.
IF they are all in use, buy a splitter, disconnect a connected molex plug, plug it into the splitter and then connect whatever one to the USB hub and one to wherever it was already plugged in.
Thanks to all of you who ans my question
But thats not compelet ans
My power supply hans no molex connector so is there any option to install
molex connector
Sata power connect
Separately
There is no option in power supply for molex connector
I did a quick search on the T7910, and found images of the PSU and motherboard.
That's a workstation system, and while I see SATA ports on the board, I don't understand how the SATA drives would be powered... I did a VERY quick search, and found the manual here, but it seems like the drives just slide in and plug into something - I didn't see any SATA cables except for where the manual talks about removing the optical drive.
