[SOLVED] How I find true RAM speed?
Daniel8
9
Hi, how do I find my true RAM speed? Task manager shows me 2400MHz, while cmd shows me 2666MHz. How task manager, cmd and cpu-z know RAM speed? Do they measure it or do they read it from some data?
I have Asus TUF GAMING fx505dt, Ryzen 7 3750h, so it should oficially support 2400MHz, but some sources says 2666MHz. I have HyperX 2666MHz with auto XMP or something like this, but my laptop doesn't have XMP option in BIOS.
Thank you.
Open Powershell and run the following:
Get-WmiObject win32_physicalmemory | Format-Table Manufacturer,Banklabel,Configuredclockspeed,Devicelocator,Capacity,Serialnumber -autosize
Or, more specifically:
Get-WmiObject Win32_PhysicalMemory | Select-Object Speed
For more information/reference:
https://www.action1.com/kb/checking-RAM-type-with-Powershell-on-Windows.html
====== My results ==========
Manufacturer Banklabel Configuredclockspeed Devicelocator Capacity Serialnumber
029E000080AD 2133 DIMM1 8589934592 00000000
029E000080AD 2133 DIMM2 8589934592 00000000
PS...
PS C:\Users\UserNameHere> Get-WmiObject Win32_PhysicalMemory | Select-Object Speed
Speed
2133
2133
