How important is it that I set the CPU ring voltage and System Agent voltage if I only plan to overclock my CPU?
ext2074
8
How important or unimportant is it that I set the CPU ring voltage and System Agent voltage if I only plan to overclock my CPU?
I think it doesn't matter but just want to be sure.
I'm using a Gigabyte z97 SOC Force btw
Thanks!
CPU Ring voltage is like VCore for Uncore. Performance gains from overclocking uncore are tiny, I wouldn't bother with it much.
System Agent Voltage is the voltage for things like the integrated memory controller. Upping it a bit can help stabilize high speed RAM and a few other things, none of which are significant for day-to-day overclocking.
Basically, if you just want to get a basic OC going there's no need to mess with these voltages.
In that case then, is the System Agent voltage important for the my Corsair Vengeance pro 2x8GB 1866Mhz Corsair Vengeance Pro or is it fine to just keep the XMP settings?
You shouldn't need to adjust System Agent Voltage for 1866MHz RAM, and if you do then the XMP profile will probably do it for you.
In my own rig System Agent was automatically set to only +0.1V when I enabled XMP, and that's with 2400MHz RAM. 1866 is a piece of cake for Haswell memory controllers.
