How is Arctic Liquid Freezer 120?
EK2001
19
I am planning to buy a new 120mm AIO becasue my case supports air coolers up to 155mm and 120mm radiator only. I saw the Arctic Liquid Freezer 120 and it seemed good to me but I wanted to ask you too. How is Arctic Liquid Freezer 120?
Between that in the corsair h60, stick with the corsair H60, the fans rpm speed is much faster.
The artic liquid freezer 120 is abit too slow, you don't want that especially if you oc off and on during the year.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181030&cm_re=h60_corsair-_-35-181-030-_-Product
Use this grease with that and you'll be fine for the next 6 months or so.
http://www.newegg.com/Product/Product.aspx?Item=9SIA2W04SS3906&cm_re=thermal_paste-_-35-154-012-_-Product
But according to tests, arctic liquid freezer 120 has much better performance than Corsair H60. http://www.hardocp.com/article/2016/02/11/arctic_cooling_liquid_freezer_120_aio_cpu_cooler_review/3#.WFFtgfmLSUk
What is the best 120mm cooler in H75-H80i's price range?
