How is my first gaming PC build?
Codfunnyhill
35
http://ca.pcpartpicker.com/p/26M80
I was trying to keep the total cost under $600
I mainly want to play gta v , and some bf4 for my youtube channel. The price is really important so if you suggest anything please keep it under $600
I would like to eventually crossfire with the 7870.
Please recommend anything better, but It can't be over $600, I would like to crossfire or sli later.
Please let me know what you think!
it is optimized version of your build
fx 6300
1TB
better case
the best quality PSU for Crossfire (fyi:avoid coolermaster psu)
lower price (thanks to sapphire GPU)
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($114.98 @ Newegg Canada)
Motherboard: ASRock 970 Extreme3 R2.0 ATX AM3+ Motherboard ($65.00 @ Vuugo)
Memory: Kingston Predator Series 8GB (2 x 4GB) DDR3-1600 Memory ($55.69 @ Amazon Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($62.98 @ Newegg Canada)
Video Card: Sapphire Radeon HD 7870 GHz Edition 2GB Video Card ($174.00 @ NCIX)
Case: Antec One ATX Mid Tower Case ($34.99 @ Memory Express)
Power Supply: Antec HCG M 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($69.99 @ NCIX)
Optical Drive: LG GH24NS95 DVD/CD Writer ($17.00 @ Vuugo)
Total: $594.63
(Generated by PCPartPicker 2013-11-22 20:10 EST-0500)
Thank you, but the problem is that I only have 600 possibly 650 max to spend. So even if there was rebates I still could buy it, I also don't need a optical drive.
Forgot to add I was going to crossfire in the future when I have the money to buy the card, I woud also buy a better psu
Does that mean you only have ~600-650 without rebates?
Also, don't crossfire with that board! The second PCIe 2.0 slot runs at x4 so you will get nearly no performance increase in crossfire! Getting a motherboard that can properly crossfire will cost a lot more. Are you fine without the option to crossfire so you can get the best performance right now?
Yes i'm fine without crossfire for the best performance, What I mean about rebates is I only have 600 to spend, so with rebates the cost will be over 600, even though I will get the money back. I just don't have the money to spend up front.
$650 is absolute max.
is there another motherboard that might be better
I also don't need the optical drive
Without rebates:
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.79 @ DirectCanada)
Video Card: Sapphire Radeon HD 7870 GHz Edition 2GB Video Card ($199.00 @ NCIX)
Case: BitFenix Shinobi Window ATX Mid Tower Case ($59.99 @ NCIX)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($44.99 @ Memory Express)
Total: $632.42
(Generated by PCPartPicker 2013-11-23 13:39 EST-0500)
Total adds up to $632, and then with rebates it goes under $600.
Smaller psu since you can't crossfire on that board.
Better quality case, IMHO.
Added cpu cooler to overclock.
