I have a cool master CM690( http://www.coolermaster.com/products/product.php?act=detail&id=2908) case.
i havent assembled anything yet cause i wanna install the fan 1st.
heres my current setup
amd phenom II x4 940
4gig memory
750w psu
1tb hd
dvd burner
gfx card(currently using a cheap 1.. will buy a better one later)
my case can have 7 fan installed at one time. i have been reading stuff bout air flow inside the case.. and heres wut i drawn up.. (pardon the crude art skills)
Im tryin to create a postive air pressure inside my case. so there wont be as much dust.
onl the bottom and rear exhaust are filtered..
is this a good fan setup?
can anyone recommand some good fan for my need? <$10/fan with blue LED
4gig memory
750w psu
1tb hd
dvd burner
