How likely will my PSU let me down for the first time ?
Hello guys here is my build:
Case: Aerocool Aero 800 (2 front Corsair 120mm fans+1 Aerocool 120mm exhaust fan at the rear)
Power Supply: Corsair CX 750W
Motherboard:Gigabyte 970A-UD3P rev 2.0
CPU:AMD FX 6350 OC'd at 4.2Ghz with Coolermaster Hyper TX3 Evo
Ram:2x4 gb DDR3 1600mhz Samsung
Graphics: MSI Gaming Radeon R9 380 2gb DDR5
Storage: 1- SSD Samsung 120 GB
2- HDD Western Digital 1TB
The PSU I know it is a pile of rubbish but it has served me well on my previous not powerfull at all PC.
The 2 Corsair fans added to the case are connected to the motherboard and for some reason I cannot change the RPM, they are running full speed all the time. I also want to modify even more inside the case.I was thinking of 2 intake fans at the front, 1 intake fan at the rear and 2 exhaust fans at the top of the case and buyin a good fan controller. I have red that a 6 fan controller fully loaded can use up to 180W. DO you guys think my PSU will take all this like a man or just die trying ?
A 6 fan controller WILL NOT use 180W! A single fan uses between .05-.2A of current at 12V. That is roughly .15W per fan equating to roughly a full watt over 6 fans. 180W is just nuts. Your PSU will be able to supply the power no problem. Yes you are right, it is not the best, but fans are the least of your worries and the PSU will handle them like a printer handles paper.
You should be fine. 750w is PLENTY. However, Corsair cx 750w has been spotty but for the most part if nothing goes wrong within a year you're out of the woods. Get a fan controller to control your speeds and always make sure it's in a suitable push pull configuration. In other words, intake-exhaust are placed and offer the proper air pressure difference inside the chassis compartment for maximum airflow. Good luck!
Could you please explain what is push-pull configuration ?
Keep in mind that these units are not very good at handling high temps so make sure it doesn't intake much hot air. Is your PSU bottom mounted?
Overall if you already own it you might as well keep it. At least it contains the proper protection circuitry so that if it does fail it probably won't damage your stuff.
See this airflow diagram . You want cool air in the front and hot air out the back.
data:image/jpeg;base64,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
Yes it is bottom mounted but I am also worried a bit because of the cover inside the case which is covering the PSU and 2 HDD bays altough it has plenty of space under the case where the PSU fan is mounted.
How would you suggest I add 2 more fans into my case?
No need to worry about a PSU shroud, the fan pulls air from under the case so you're fine there. I don't recommend buying the CX for new builds since there are much better options in the same price range, but again since you already own it you might as well keep it.
OK guys so I bought the Aerocool CoolITouch-E . My opinion on it.....the fan molex connectors are a bit useless and I wish I could just pull them out. Cables are decent in lenght so no worries there. The acutal device does live a gap in my front panel ( not the exact size ) and for the worst part......it's giving me a coil whine like I have never heard before. My PSU had the same problem when I bought it 2 years ago but I managed to solve the coil whine by updating my BIOS driver and it was a pretty loud PSU, but honeslt nothing like this fan controller. So I have made some tests with it by playing with the fans stoping them one by one adjusting speed and nothing seems to stop it from whining. I have since unplugged it and replugged my fans into my motherboard. I would rather listen to 3 fans spinning at 1600 RPM than that annoying coil whine. Any suggestions?
