wesambukhari Prominent Oct 1, 2017 13 0 510 Oct 6, 2018 #1 I have a simple question, will the led's in my system(GPU, MOBO,Ram) die faster then the ones outside due to constant heat around them?
Solution D Deleted member 217926 Oct 6, 2018 I think the standard is 50,000 hours. That's 50,000 hours until it dims to 70% of the original brightness.
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Oct 6, 2018 #2 No, not on a timescale that matters to you. Upvote 0 Downvote
D Deleted member 217926 Guest Oct 6, 2018 Solution #3 I think the standard is 50,000 hours. That's 50,000 hours until it dims to 70% of the original brightness. Upvote 0 Downvote Solution
