How long will it take for ink to dry on double sided gloss card
The Inkjet photo gloss card stock is designed for use with color inkjet printers. Just keep in mind that you should use only paper that is designed for an inkjet printer, and to use a high-grade paper for the best results. If the paper is not designed to be used in an inkjet printer it may never dry. If it is inkjet printer paper it should dry in under 10 seconds but it is good not to touch it about a minute just to make sure.
Latest posts
