Question How many degrees celsius does a good cooler reduce?
Jan 29, 2019
11
generally speaking, how many degrees does a decent cooler reduce ? also, i have a i7 3770 , how many degrees it can take the heat before start "killing" the processor ? i have read it is 68 degrees. is that correct?
USAFRet
114,595
2,122
157,240
18,640
"how many degrees does a decent cooler reduce"....compared to what?
Generally, you don't want the CPU to go over 85C under load.
Reactions: JQB45
According to intel, 100c is the max temperature the CPU should be at.
Really under 80-85c is ideal.
A cheap Cooler Master H212 will drop temperatures a lot compared to a stock cooler on an i7.
