Kahlo kahlow :
ko888 :
Kahlo kahlow :
ko888 :
A master Bluetooth device can communicate with a maximum of seven devices.
Then I guess you don't know if that's a ''master bluetooth'' device?
Yes it is.
Also, will it interfere with my wifi connection? I use a separate usb wifi adapter.
I heard that bluetooth and wifi work the same way. Just want to know if it will apply to this or not.
WiFi LAN communication protocol is completely different and is used when high speeds are required and communication distances are much further.
Bluetooth is meant for low-bandwidth communication between two or more devices that are near each other. The Bluetooth radio signal is also of much lower power.
Many laptop computers have both WiFi and Bluetooth and they don't have any problem when both are being used.
I'm not saying that it's impossible, just that it will rarely happen.
