bit_user Titan Ambassador Jan 20, 2010 19,993 10,977 79,540 Jan 3, 2023 #1 I did a few web searches. I ran across a few mentions that there are 3 different dies, but all the focus seemed to be on the largest (8P + 16E). Ideally, I'd like to know the top spec CPU models that use the second & third dies.
Solution Fix_that_Glitch Jan 4, 2023 Here is a good article. Intel 13th Gen Core Raptor Lake-S range leaks 4 to 24 cores on three separate dies (updated) (guru3d.com)
Fix_that_Glitch Judicious Mar 31, 2019 7,084 815 32,940 Jan 4, 2023 Solution #2 Here is a good article. Intel 13th Gen Core Raptor Lake-S range leaks 4 to 24 cores on three separate dies (updated) (guru3d.com) Upvote 0 Downvote Solution
bit_user Titan Ambassador Jan 20, 2010 19,993 10,977 79,540 Jan 5, 2023 #3 Fix_that_Glitch said: Here is a good article. Intel 13th Gen Core Raptor Lake-S range leaks 4 to 24 cores on three separate dies (updated) (guru3d.com) Click to expand... So, I guess the answer is that there's only one Raptor Lake desktop die, and everything else is derived from an Alder Lake Refresh? Reactions: Fix_that_Glitch Upvote 0 Downvote
Karadjgne Titan Ambassador Dec 26, 2012 30,759 4,553 142,790 Jan 5, 2023 #4 You'd expect anything less from Intel? AlderLake+ has plenty of room for additional +'s, Intel is going to get its moneys worth out of that architecture. Reactions: Fix_that_Glitch Upvote 0 Downvote
