How many fan connectors on GA-B57M-D3H
yoyoran
Commendable
May 12, 2016
43
Like the title says: How many fan connectors does the GA-B57M-D3H have? Not that much of a question but I couldn't find the answer on the internet :)
Okej thanks for you reaction. I was planning on adding more fans into my case. Do you have any idea if this will work as a good way to connect more than 1 fan to the motherboard? And can i connect the CPU fan to this thing aswell? https://www.newegg.com/Product/Product.aspx?Item=9SIAE3060P0642&cm_re=case_fan_hub-_-11-984-004-_-Product
thanks in advance.
