How many fan headers does the gigabyte z170 hd3 have
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Wondering how many fan headers does this mobo have, because i am planning to add about 2 case fans to the existing 2 of my spec 02, as well as the fan for my aib (fans for cpu does have a reserved spot right?)
Just need a simple answer, and i hope it is 6 or aboveexcluding the cpu fan ,so that i get to choose where to place it in case of short cables
Then in the case you haven't built it yet, see how it performs first. For what it's worth I used to have 7 fans running on my PC, I thought more was better. I only use 4 now and I have seen no difference.
If i were to choosebetween:
- only 4 in total, would 2 intake, 1 exhaust and 1 radiator fan (and throwing the non led fan from the spec 02 away)
-buying an extra adapter (and i would'nt just find a cheap one, but something that can fit my build (appearance matters imo)
which one will be worth it.
personally i wont want to pay extra just to get slightly better temps, and i never liked the non led fan anyway, but i would like a second opinion.
if i find one, i will probably get it, but i wont specifically buy it, since my parts are arriving tomorrow, and i would like to have it set up (fully set up with everything installed) by sunday
2 intakes at the very front radiator at the back, and 1 exhaust on top (if possible the furthest back, otherwise at the top of the centre of the case.
