How many fan headers does this motherboard have>
ajsski99
273
Hiya, my friend has purchased the Asus H110M Plus motherboard for his build. the case we chose only has 1 pre-installed case fan so we bought 2 more arctic cooling fans. however the thought just struck me that if his motherboard doesn't have enough fan headers we are kinda screwed. so how many fan headers does the ASUS H110M Plus have?
if it doesn't have enough what can we do?
All replies are much appreciated, Ajsski99
It's all right here: https://www.asus.com/Motherboards/H110M-A-D3/specifications/
and here: https://www.asus.com/Motherboards/H110M-A-D3/HelpDesk_Manual/
1 x CPU Fan connector(s) (1 x 4 -pin)
1 x Chassis Fan connector(s) (1 x 4 -pin)
Thanks so much!
so we would need to buy a fan splitter? where would i find these? could you link one?
Yes, you would need a 3 way fan splitter. You could use 3 or 4 pin depending on number of wires on fans. You can also get a Molex or SATA to fan adapter and connect extra fans to PSU directly if you don't mind them blowing full speed all the time. Even if you do connect them all 3 to CHA_Fan connector on the MB and if one of them is not identical to other 2, speed control may not be accurate or even possible.
If you need to control them precisely, a case mounted controller is in order.
Any good real or online store should have them.
