how many fans? cooling question
All the specs for the case are listed in the link below. It will give you fan capacity as well as all dimensions of the case. You can then just look up the size of your components to see if they do ineed fit.
http://www.nzxt.com/product/detail/95-phantom-410-mid-tower-case
