I'm thinking of buying a new atx case for my gaming needs, so how many fans do i actually need for it?
It depends on the case and hardwareI have Asus gtx 1060 6gb rog oc, intel i5 7600k, basic Asrock mobo, 8gb ram, 700watt psu and only one fan currently.It depends on the case and hardware inside of it.
Used bitfenix atx ghost with only top filter.
Is bottom intake ok?You don't have high end hardware that will generate a lot of heat. Just make sure you have a front intake and rear exhaust.
Bottom intake can improve graphics card temperatures. Check this video out:Is bottom intake ok?
