Question How many fans do I need?
Nov 7, 2019
hello all. https://pcpartpicker.com/list/4sBvWb this is my build. I was wondering about the number of fans I need for this case. I will be using this pc for streaming competitive fortnite.I have already added 2 fans but I don't know if that's excessive or too little. I don't know anything about air pressure and stuff like that since this is my first build. Pls, help =) thx!
This is what I'm seeing for that case>>>
The case fits either two 140mm fans up front or you can remove part of the power supply shroud and fit three 120mm fans up front. There's one 120mm rear exhaust fan. The top fits either two 120mm or two 140mm fans.
I would put two 140mm fans up front as intakes.
I would put two on top as exhaust.
I would have one in the rear as exhaust.
Nov 7, 2019
so 2 140mm fans on top as well and 1 140mm in rear? just to make sure thanks!
