Hello everyone!
I have a year old system inside Fractal Design Define C case. When I built my rig I bought a third fractal fan so I've had 2 in front and 1 in the back. I used the stock CPU cooler till now but as I have started to OC my Ryzen 5 1600 I decided to invest in an Corsair 240mm AIO. I installed in the front to give cool air to the CPU and because it was easier to get the hoses in the front (The radiator would be so close to the CPU on top that the hoses aren't easy to bend. So at the moment I have the rad in front with two fans and one fan in the back and two in the top. This probably means I get negative pressure.
So the question is how should I configure my fans? Should I remove the two on top and just go with rad and one in the back? Or is it ok to have the 3 exhaust fans? Or maybe I should ditch the HDD rack and put on from the top to the bottom to have positive airflow? Or just try to fight the AIO to the top and use the original fan configuration? What are your thoughts?
