How many FPS can I run BF3 on low-medium with these specs?
imback
56
CPU: AMD-FX 6120 SIX CORE 3.5 GHz
GPU: EVGA GTX 650 TI BOOST 2GB (no superclock) on pcie x16 2.0 slot
RAM: 8GB ddr3
PSU: Cooler Master eXtreme Power Plus 500 WATT
OS: Windows 8 ultimate
more info? Ask please
You will get some good frame rates with this setup on low settings probably above 60 fps. I used an fx 6100 with a radeon 7850, similar to what you have and I was getting anywhere between 40 and 100 fps on bf3.
does a factory superclocked card heat up more than a original? becausue I dont know if I should get the SC version of my GTX.
whats the FPS difference between the two?
