[SOLVED] How many GPU do i need in order to use 6 monitor as one for gaming
paktazh
11
I got a pc with
GeForce® GTX 980
and 3 monitor i want to connect 6 monitor for surround gaming Do I have to get another GPU and doing SLI? or there another way
thanks
I do not even know if this will work but.....
Do your current monitor have Display Port?
Each Display Port should be able to drive 2 monitors (depending on the resolution). It will be an expensive setup cause if it works you will a need current top of the line GPU to drive such a huge amount of pixels with at least 3 independent display port . And thats if the games can be configured to work on 6 screens. I know most games can run on 3 monitors but never tested more than 3.
The bad thing about SLI and Surround is that its not supported by many games, and specially not the newer ones. I tried this at work when I build a Video Wall with 6 screens and 2 GTX 980 (I think it was 2015) and it did run 2013 Tomb Raider in a "decent" way expanded to all 6 screens but that was it, the other game I tried did not work and it supported SLI according to developers.
First off, are you expecting to game at all 6 monitors at the same time? If the answer to that is yes, then even at light games, you need a much better GPU.
List your full system specs and what games are you planning to play and at what resolutions.
Reactions: RodroX
Corwin65
That GPU is from 2014 so by today's standards it's not really good. It is old technology and you will need better cards. You will almost probably need a new PSU as well.
Need to know what games, what resolution, and what PSU you have.
Reactions: RodroX
paktazh
11
i got evga 1000 g2 power supply
mostly play war thunder 1080 or 4k
i wont make new pc because of Crona i am broke but if i sli another 980 i will be able to get 6 monitor as one from this ? what GPU do u recommend thx
nofanneeded
Respectable
Sep 29, 2019
1,562
252
2,090
52
You can use 6 monitor outside games in SLI , but for games you cant.
for upto 16 monitors you will need nvidia Quadro cards
for 6 monitors , AMD Radeon Pro cards , like
https://www.bhphotovideo.com/c/product/1521630-REG/amd_100_506085_radeon_pro_w5700_graphics.html
paktazh
11
But would i be able to install AMD Radeon Pro cards in intel x99 motherboard ??
nofanneeded
Respectable
Sep 29, 2019
1,562
252
2,090
52
in that case maybe i should buy the new LG 75 in Nano tv that will do the job what u think
it is a nice choice ... but get only the Nano series not the normal series if you want to game on LG.
this one
https://www.bhphotovideo.com/c/product/1560621-REG/lg_75nano85una_nano85_75_class_hdr.html
also , dont get nano80 , get nano 85 , because it has 120hz refresh rate and supports ALLM and AMD freesync
https://www.lg.com/us/tvs/lg-75nano85una-4k-uhd-tv
Dont get any nano tv below 85 models , 85 and above (this is not the screen size, it is the model)
paktazh
11
Thank you all
but still if i add one more different kind of GPU no t doing Sli would i still be able to run 6 or 5 monitor just for daily work thanks
