How many Heat monitoring tools or Software programs should I have?
Leadbelly78
724
I mean, I have HWMonitor , RealTemp & the Corsair Link Dashboard. What am I talking about, you guys, galls know them all.
Some people said that you should a huge amount of them. I have Corsair Link Dashboard.
So, anybody have any suggestions?
Sorry if I this questions has been asked before.
Don't know about Aida64.
The objective of a stress test is to run the cpu very hard using the instructions that are common to many applications.
That is a more realistic stress for most of us.
Prime95 uses only a subset of instructions.
Ok, thanks for the quick reply.
EDIT: If I plan on OC my CPU, should I do the same, removing the heating software, sorry for the stupid aZZ question.
I heard that OCCT & Aida64 can really heat up a CPU a lot and quite fast but you suggest OCCT.
I'll check that program out once I get a chance.
Thanks.
I just have one more question. Using a program such as Prime95, Aida64 and the other tested isn't that realistic is??
Honestly, If I used a program like mentioned above.
I just wanted to mention that I'm not OC
Sorry, you just answered my question.
Sorry about that
