How many pins needed on ribbon cable?
PandaBear88
Commendable
Jul 30, 2016
84
I need to replace a ribbon cable with "JI-HAW AWM E118077 2896 80C 30V VW-1" printed on it, but on ebay the same cable is for sale with different numbers of pins. how do i know how many pins it should have?
thanks
the cable goes between the keyboard section and main section of a laptop. no clue which things it connects.
Then, your best bet is to follow the advice of MasterWigu, and count the pins on the cable you are replacing.
can somebody tell me if this cable looks like it's in okay condition? to me it looks like they bent it more than it should be.
http://www.ebay.com/itm/JI-HAW-AWM-E118077-2896-80C-30V-VW-1-Genuine-Laptop-Ribbon-Cable-6-Pin-3-Long-/322330087140?hash=item4b0c5ecee4:g😀H4AAOSwNnRYlRc~
is the link showing?
That would depend on the amount of clearance that exists in your laptop, particularly on what's around the header that you will be connecting.
