how many pumps will do?
Tony Wayne
8
i am using 2 360mm rads and 1 240mm rad with one tube reservoir....will one pmp 500 pump get the job done or i need to get another pump and reservoir? running dual evga gtx 780ti's in the loop as well. thanks for your help
ty, really a beginner at building.........when you say parallel that means just another pump in the loop somewhere, or add another reservoir and pump (one res and pump with rads to the cpu, and one reservoir and pump dedicatated just for gpu's?) ty so much for the help.
Actually that would be series, but depending on your loop. series might be better.
