Based upon the standard design goal of 10C delta T....
At 1250 rpm fan speed, each 120mm of 30mm thick rad will net you about 60 watts of cooling, 73 in push / pull
At 1800 rpm fan speed, each 120mm of 30mm thick rad will net you about 81 watts of cooling, 98 in push / pull
At 1250 rpm fan speed, each 120mm of 60mm thick rad will net you about 63 watts of cooling, 76 in push / pull
At 1800 rpm fan speed, each 120mm of 60mm thick rad will net you about 90 watts of cooling, 108 in push / pull
A HW / DC CPU overclocked will generate 140 watts ..... a 290x about 300 watts OC'd .... MoBo block about 40 watts, pumps about 23 watts each.
A 4790k w/ two 980s all OC'd about 1 x 140 + 2 x 190 or about 543 say 550 watts.
Take 60% of that for...
