How many radiators should I get for my loop?
minimum of 240mm/280mm still
360mm would be better if planning to overclock
could be 1 360mm or a 240mm and a 120mm
or even a 280mm and a 120mm
a rough guide is 120mm per component being cooled plus 120mm for overclocking
but thats a rough guide only as other variables such as reservoirs,pumps etc can alter that a bit
gpu is 1
cpu is 2
motherboard is 3
or if its a monoblock then would consider that as cpu as well probably
but still cant see how its 4
I'm running sli
