Hello, I am going to buy a new motherboard and I might as well go nuts with the RGB. But I am not sure about the limits of one RGB fan header can take, and I can't seem to get a definite answer googling. So I am going specific.
I am planning on getting this mobo:
www.asus.com
9 pieces of these ARGB fans:
http://www.idcooling.com/Product/detail/id/173/name/XF-12025-ARGB-TRIO
And this ARGB cooler:
http://www.idcooling.com/Product/detail/id/193/name/SE-224-XT ARGB
So my concern here is if the mobo's two RGB fan headers are enough for a total of ten ARGB fans.
I will definitely use the splitters that come with the ARGB fans but if needed, I might buy a separate splitter with larger capacity. I've seen some RGB splitters online that can connect up to eight fans and some are even up to ten. Thanks in advance.
ROG STRIX B450-F GAMING | Motherboards | ROG Philippines
Best AMD AM4 B450 Ryzen ATX gaming motherboard with advanced cooling, Aura Sync, SupremeFX, dual M.2, Intel LAN, and USB 3.1 Gen 2
