How many switches do i need to connect 50 computers with 8 ports on each switch
dena123
I have a total of 82 networking devices, there are two areas where clusters of computers will outnumber the wall jacks in close physical proximity, I need to use economical, desktop switches, I need to know how many, what kind, and at what price, thank you so much
You lose one port on each for its network connection, so if you use 8 port you have 7 available -- to connect 50 devices you would need 8.
Look at bigger switches, the 16 or 24 port are pretty reasonable. You could get by with 2 24 port and an 8 port.
If you want consumer grade unmanaged switches look at TPLINK and Trendnet, they work as well as other inexpensive brands.
Do you need gigabit or just Fast Ethernet (100Mpbs)? Personally, I would lean toward spending the extra and getting gigabit -- the inexpensive 24 port Fast Ethernet are around $50-60, while the gigabit are around $120 each.
