Hello Guys, i want to know how many system fan headers are on MSI H110M PRO motherboard? I want to buy it but confused as my case has three fans. But i think this motherboard has only one. Please help me.
You can get Molex to multi-fan connectors online like this one here http://www.newegg.com/Product/Product.aspx?Item=N82E16812423164&cm_re=molex_to_fan-_-12-423-164-_-Product and as long as you have a Molex connector on your power supply your fans will power up. Although if you want to put the female header into the motherboard for RPM control, your fans will all have to be the same size, max/min speed and power consumption (I recommend using multiple fans of the same brand and model). But if you just want them to turn without RPM control, then you don't even need to plug the female header into the motherboard, instead just connect the Molex connector to the power supply and all the fans to the male connectors on the adapter.
The RM550x has four Molex connectors, they're just under the new name of 4-pin peripheral connector. However, I have never personally used a Corsair PSU so I cannot tell you whether this model is a good quality or not. But in terms of "will it work", yes it will.
