If you're in the US, don't worry about Voltage so stop reading this paragraph here. If you're outside of the US, you'll just have to make sure your computer's power supply is set to the correct voltage for your area. You'll also have to make sure you get a PSU that matches your computer, TV, and PS4's voltage setting (110V or 220V). In short, you'll need to make sure you're matching the Voltage for all items, including whatever Voltage is coming out of your wall outlets.
Wattage is basically a measure of how much power is being used by each item.
Are you wanting to run your TV, PS4, monitor, and computer if the power goes out? Keep in mind that a PSU will only last for about 15 minutes before running out of juice. It's just meant to let you get to a save point rather than keep you running through a power outage. You'd need a generator for that.
If you're going to buy now, I wouldn't skimp out. If you want to run them all, you'll want to get a UPS that can support all devices at full bore. Otherwise, you could run the risk of under powering one or all devices which can cause damage.
Unfortunately, you'd be right over the 900W line, which seems to be a common step in UPSs so you'll probably need a 1000W UPS. Not cheap.
You'll also need to make sure it has enough outlets for your devices. I assume they would need one each for a total of 4 outlets but that's won't be a problem, give the Wattage. I'd personally suggest plugging your modem and router into this device as well. A 1000W supply will cover those.
You could take a change and go down to assuming your PC only pulls 450W. That will greatly cut your costs.
You could also only plug in your PC and monitor and get a UPS that covers those. That will let you shut your computer down properly in the case of a power outage. That would be the most practical way to protect your system. The other devices won't have an issue.
Here's a link to NewEgg that will show PSUs that will cover the first scenario I talked about:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007932%20600013485%20600013493%20600013495
