How many Watt does my psu need to offer for my setup?
zjef
38
Hello there
My question is in the title how many watts does my psu need to offer for this setup:
CASE: Cooler Master Storm Scout II Advanced
MoBo: Asus SABERTOOTH 990FX R2.0,sAM3+
CPU: AMD FX-8350 Black Edition,sAM3+
CPU koeling: Corsair Hydro H60
RAM: Corsair XMS3 1333 (4x4GB)
GPU: MSI radeon R9 280X gaming, 3GB (CrossfireX)
SSD: Samsung 840 EVO 120GB
HHD: Seagate Desktop HDD 2TB - 3.5inch
CD-ROM reader: Samsung DVR DL 24X,SATA
Case Fans: cooler master sickleflow BLEU (X4)
So wich psu would fit for my setup?
Am I looking at like 750W?
thanks alot!
greetz
Zjef
Yes thanks for the info, but i will run 2 r9's so crossfire.
Would a corsair cx750 b enough for my setup and croosfire?
A 750W CX might be a little tight for a pair of 280X: you might end up pushing it to ~90% if you run things like Furmark. So you might want to step it it up one notch.
Would a OCZ Fatal1ty 750W be ok? Would I get 100%? Also you think this is a good setup for call of duty games, cuz I would play such fps games...
Most half-decent PSUs can go to 100-110% load at least for a while when they are fresh off the assembly line. The reasons for not recommending running even good PSUs at that high of a load is due to aging and efficiency: PSUs are usually most efficient between 40% and 70% load while aging will degrade the PSU's output quality over time and this tends to occur more quickly with increased load.
As long as you do not plan to run extended Furmark burn-ins, 750W should be enough.
