How many watts do I need for my build (The PSU)
krisdj
29
I am getting an Intel i5-4460 and an EVGA gtx 750 ti, how many watts will I need? I currently am currently planning to get a Corsair Builder 430W 80+ Bronze Certified ATX Power Supply. Will this be enough? Thanks
P.S. I am on a budget
I understand that but that Corsair PSU isn't the best and it's entry level. It will definitely do the job but if you can afford a seasonic I would definitely choose that
You have good components so I'd definitely recommend matching them with a quality PSU as a bad quality PSU can kill your system. Here are some recommendations:
Seasonic S12-II 520W 80+ Bronze Certified Wired Power Supply (£48.06)
XFX ATX 550 Power Supply (£63.90)
Both of the above will be fine with respect to wattage required and they are made excellent manufacturers
Ok, here is my entire build, I am just thinking about if my psu is correct in order to function well with all my parts:
CPU Intel Core i5-4460 3.2GHz Quad-Core Processor
Motherboard ASRock H97 Anniversary ATX LGA1150 Motherboard
Memory G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory
Storage Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card
Case Corsair 200R ATX Mid Tower Case
Power Supply Corsair Builder 430W 80+ Bronze Certified ATX Power Supply
Optical Drive Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
All this is 570 dollars but I really don't want to get past 600
The PSU I currently have is 430W but pcpartpicker.com says that my build requires 252W
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor ($111.89 @ OutletPC)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($67.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($45.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Video Card: EVGA GeForce GTX 960 2GB FTW ACX 2.0+ Video Card ($194.99 @ Best Buy)
Case: Corsair 200R ATX Mid Tower Case ($49.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ NCIX US)
Optical Drive: LG GH24NSC0 DVD/CD Writer ($13.89 @ OutletPC)
Total: $589.61
Generated by PCPartPicker 2015-10-25 19:26 EDT-0400
this is a better build for gaming with a good powersupply.
the psu is 750w (that's prettymuch overkill) but the price is almost the same as a 500w psu
