How many watts do I need for my PC?
RockGamer25
9
Hello.I recently build a gaming pc and I want to know how good will my psu need to be and to know if the system is stable.The parts are:
AMD FX-8350
2 fans deepcool xfan 80l (80mm)
aftermarket cpu cooler deepcool GAMMAXX 300
hyperx fury black 8gb ddr3 1866mhz cl10
deepcool tesseract bf black case(1 fan included)
motherboard gigabyte GA-990X-Gaming SLI
hard disk seagate barracuda 1tb SATA-III 7200 rpm 64mb
and a gigabyte geforce gtx 1050 ti OC windforce 4gb.
Thanks in advance!
As a general rule a good quality 450-500W PSU can run a single GPU. Quality 650W units can run CF/SLI setups. There are some exceptions to this, but most people don't buy 300W+ GPUs or 200W+ CPUs. If you figure a normal 100W CPU and a 200W GPU then the gaming load will be ~350W. QUALITY 450-500W PSUs handle this just fine.
