How many Watts do I need to power this system
PCFnatic3
9
my build consists of:
Case: NZXT H440
CPU: Intel 4960k
GPU: MSI GeForce GTX 760 TF 2GD5/OC
MOBO: Gygabyte Ultra durable Z97X-UD3H
RAM 8gb
WaterCooler: Corshair h100i
HDD: Seagate 1tb
I am looking to add two more of the same GPU, can someone show me a cheap decent power supply that will work with thte two new GPU's. I currently have a 600w gold EVGA one. Or if you have any other recommendations to increase frame rate for games and the overall power of the system.
How many Watts?
Yes. That is what it means. Hard to say what your system would actually generate. It would be a rare instance that all three GPUs would be at full load w/o some bottleneck with a 4960. Especially at X16, X8, X4 lanes that your board has. But possible.
ok, my mobo can support the 3 way SLI though I am assuming, and I was wondering if the 3 GPUs combined would be comparable to a 980?
also, would this PSU work? http://www.newegg.com/Product/Product.aspx?Item=N82E16817139140
That PSU would work, yes. 3 x GTX 760 would be faster than a GTX 980, but it would not be as smooth. Expect some occasional stutter. It all depends on how well they scale in SLI. I've never run 3 of any cards. But I have done 2 way SLI and CF. And the heat buildup will be intense if you manage to heavily load all three cards.
I dont want to create a custom water cooling loop... is there any other way to cool them besides the fans already on them
