How Many Watts for 4770k and 750 TI ?
branrican
4
I was wondering how much power I'd be using if I was to use an i7 4770k and a GTX 750 TI 2GB. Will a 430w PSU be fine, or will I need something a bit better? Thanks for any help.
Depending on the level of future upgradeability you want, any of these will be good:
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply ($61.98 @ SuperBiiz)
Total: $61.98
(Generated by PCPartPicker 2014-05-30 13:30 EDT-0400)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($26.99 @ Newegg)
Total: $26.99
(Generated by...
Alon_Ofer
188
I wouldn't use a 430w psu because this aren't the only components you are going to use. Also you are going to have to deal with a lot of pressure making sure that the psu number of watts is enough. I would recommend a solid 650W if you are not going to SLI. Don't forget to choose for the best answer. Glad I could help.
Dylzan
1,238
Total: $61.98
Total: $26.99
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($59.99 @ NCIX US)
Total: $59.99
Power Supply: XFX 650W 80+ Bronze Certified Semi-Modular ATX Power Supply ($95.99 @ Mwave)
Total: $95.99
branrican
4
No, I do not plan to OC. So the 550w would be best then?
Dylzan
1,238
For your current setup, yes.
